Sennheiser Yo
- Dec 9, 2016
What is the correct way to connect my c5 with my phone to the otg cable? It sounds distorted when I don't connect the phone/otg cable/c5 dac in the right order
Stay updated on Cayin at their sponsor profile on Head-Fi.
If your phone support OTG and using the an OTG cable, the setup should be plug and play. Sequence is not an issue, trust me on that.
So what phone are you using ?
when im listening to the cayin c5 connected to my galaxy s5 via otg, the sound sometimes stops for like half a second then keeps playing, its annoying and happens like 3 to 5 times per song. what is the problem? is it possibly my phone? im using the c5 amp/dac with hd600s but it does the same for dt880s and hd 558s
Anyone know how the get the aux 0ower to work. I connect my phone via the aux switch and it doesn't charge. Any ideas? I am using otg, would that be a problem?
My hd600 setup.
Cayin c5 amp/dac connected to my galaxy s5.
does this sound same as straight c5? or better/worse for amp?
