JohnYang
- May 7, 2014
How's the screen quality though...
They will use a better screen with the L5 Pro.
I found the screen on the L5 to be perfectly fine in terms of color accuracy and resolution though lacking in QC. I would have rather paid less for the original screen than more for a better screen.
I like how they kept the overall design to be the same and just add the wooden back. Very classy and nice marriage of wood and metal.
I've confidence in the sound quality, my main concern is still usability, in term of interface speed, touchscreen responsiveness, playback functions etc... basically all the gripes of the L5 LOL.
Why line out jack isn't shielded on L5? ( L5 Pro gonna be like L5 without shield on LO jack?)
Is OS in L5 and L5 Pro Android?
L5 using CS3310 chip before or after the DAC chip? (so V cnotrol is analog or digital)
Is line out bypasses the internal headphone amplifier?
thanks
thanks
The os is not android-based.
The volume control is analog.
Line out skip headphone amp like all good line out do. The lineout on L5 is a beast.
Is there a browse by file option which allows for folder play?
Hi!
I have used L5 with FW1.0.0.6, I felt good sounds and looks good, but UI and the touchscreen is not good.
I like FW1.0.0.4 because 1.0.0.6 was added to the scroll function, touching something I don't touch it but often scroll another screen.
But 1.0.0.6 fixs many bugs, I must use the latest ver. So would you be able to select this function?
I use Mac so have many AIFFs and sometimes try to play DSD128 files I have, but they doesn't sound with L5 or L5 can't find their files.
Moreover I want the function of playlists or favorites like FiiO's X5. I request L&P to support AIFF, DSD128 and the playlist function.
By the way, when does next FW update come?
All I know about the next update is that it is planned to be released next week, and will address problems such as sorting.
I use l5 also, i think this is a great china player, it will not so hot when play a long time.
Hi, welcome to the family.
my L5 only can play around 5 hours ... is the 1.006 version problem ? or my L5 have some problem !?
do you know where can fix it in China !?
