- Sep 15, 2014
Hello,
as built quality is mentioned and questioned, I can inform you a bit more in depth how we handle this important matter:
1.1. One basis for high product quality and reliability is the used material (components) itself.
1.1.1. Our aim is that all parts will be either Austrian or Europe's origin. Only a few specific parts which will not be available here anymore, will come from other countries but under strict quality control of European core-suppliers.
1.1.2. The materials itself are designed for extreme long lifetime. Where possible only metal parts are used. Surface finishing are not used as design aspect only, but for highest robustness against the "real practices".
1.1.3. Just as example, plastic foam parts will not be used due to critical life-time behavior.
1.2. Tolerances of all product parts are signed according six sigma methodology. The complete quality insurance system is based on the know how of key players in high tech mass manufacturing.
1.3. All parts can be traced back from the final product to the specific supplied material batch.
Allowing this, the serial number will be encoded and include all relevant data.
1.4. A specialty will be the robustness against dust and water. The product will be even washable!
Please understand that this tread is not ideal to explain every detail, but my promise, that you will read more in the upcoming homepage of Mysphere.
BR heinz
This is incredibly reassuring...amazed to see the level of participation here.
