Gradofan2
- Jul 2, 2005
Yeah... I think that must be it...
I noted in the following thread... similar distortion in the mids (rough mids): http://www.head-fi.org/forums/f4/d50...rs-1-a-313265/
But... I tried them out on my portable Shellbrook MaxiMoy and the rough mids disappeared... but a bit "boomy bass" and weaker treble appeared.
I had rough mids with my DV332... but... the bass was nice and tight, and the treble was superb. I'm guessing the DV332 doesn't have enough current to properly drive the 25 ohm D5000s (a bit like the Grados), whereas the MaxiMoy has enough current, but maybe not enough voltage, or whatever.
So... a lot of the "gremlins" in the D5000s may well be related to "system matching" - or - the lack of it.
That's just great... another set of phones... that need careful matching with the setup. My guess is... the "Markl mods" may not even be necessary... if... you've got the right set up.
Originally Posted by helios4 /img/forum/go_quote.gif There is probably another reason. I have also a D5000 (stock) and I do not have resonance, distortion etc...like you describe with my hybrid amp. And no fatigue at all - the opposite I can use them for hours and the bass are correct. Maybe your phones have a problem or the association with your amp is not good ? (note: the symptoms you describe remind me my ultrasone HFI780 ![]() |
