nycbone
- Dec 30, 2008
The VDAC has line level outputs so you would need an amp.
josep;5557613 said:+1
A decent PSU rated at least 50W will do, one 90-120W unit runing at 12 to 13'5V is perfect and you may have it for (well) under $50 (ePay).
Based on this kind advice I went to the local electronics shop yesterday and bought a switchable power supply delivering 5000mA at 12V (i.e. 60W). The package contains six output plugs, one of which fits the V-DAC. The guy in the shop connected the output plug in the correct polarity for me (crucial), so nothing could go wrong.
And things couldn't have turned out better!! The PSU works like a charm. All my reservations are now gone! My original source has a big PSU and this turns out to be the missing element with the V-DAC.
No more questions from my side concerning prat, impact, attack, upsampling downside or what-so-ever..
The sound has become spot-on with more control and punch (strong and taut bass).
Instruments are loaden with energy.
And there is improved definition, with velvet-black background (poetic terminology from ADD) and no more "small fruits splashing against the wall" (also proza from this forum) as was evident from a somewhat blurred sound before.
Thanks again for this recommendation. For only 30 Euro I am now completely satisfied.
Here is a link to the PSU I use:
Best switch mode power supply 6V - 15V (up to 5 Amp) at e.g.:
AC/DC Adapters
Now that have been using the Powerking PSU for some time, are you still happy with it and does it run warm, or cause the VDAC to get warm?
Both the PSU and the V-DAC get slightly warm. The original walmart, by comparison, used to get hot. Now that I have lived with it a bit, what is stunning is the dynamics are so much better. It feels as if I am using a more powerful amp. At £25 it is no brainer because the Powerking is a variable voltage multi- adaptor, so can have many uses.
