How about the Yamaha EPH-100? strong bass, small form factor, good build quality. No mic/controls. $110 on Amazon.
Definitely a good option. Didn't realize they were down to $110. I'd be careful buying them on sale due to counterfeits but if it's sold by amazon it should be fine.
Once again, Mr. Joker's review lines up with mine, and joker's got to be the most honest and trustable reviewer on headfi. You have to tread headfi carefully because you will run into lots of hype and possibly scammers posting that get's paid for only writing positive things. Joker has much experience, low-fi to hi.
Joker, I've noticed that NT-6 is sensitive to source. NT-6 can be extremely clear and detail, or sound like any other iem depending on the source. Have you tried several sources? I found that if you match it with the right source, it would push out some unbelievable sound, dynamic imaging is ridiculous. My top three sources are DX100, ODAC/O2 combo, and Fiio X5. Maybe your ranking would go up even more if you try it with the right source?
I don't know how much room for improvement there is on top of the HM-901 with IEM card - I've tried the AK120, DX50, X3 and didn't think either was better than the 901. Plus, there's not much room for growth in the NT-6's score anyway - it's 2nd overall
Hello
Joker,
What's the best IEM I can purchase without going for broke?
1. I'm looking for tight and noticeable deep sub-bass (not necessarily a bass-head type)
2. Clear and liquid-like sounding mids'
3. Finally, clear and analytical treble (not dry)
-A mild V shape is the idealistic sound I had in mind
.....I thought about the Dunu DN-1000 (triple driver hybrid), if paying in the $200 dollar range.
But, I'm trying to shoot under $50 dollars (or only above $50 if any BA's are worth getting that could provide all of the above).
-Some ideas would be great! Thanks in advance!
My reply, for posterity:
Sure, but that's a lot of stuff you want for $50. You'll have to compromise just a little bit - either with the VSonic VSD1S, which is v-shaped and very clear with crisp treble but doesn't have the best deep bass extension, or with the SteelSeries Flux, which is less v-shaped and has better bass extension, but lacks a little bit of midrange clarity and "liquid-ness" compared to the VSD1S.
ljoker , can you please put a suggestion , either here or on this thread
http://www.head-fi.org/t/722687/iem-choice-upgrade
on what I should upgrade my ie8 and ck100 into ? I am using the x5 as a source
I would say EarSonics SM64 based on those requirements. Not having tried the SD-3S (the new small version) I'm not sure how it fares in comfort but I've never had a problem wearing the EarSonics for hours. They tick the other boxes, too - good deep bass but not IE8 levels, warm sound, pretty easy-going overall considering it's a high-end BA monitor, and so on.
Hi Joker. I had read your thread since 2011 and has managed to make fabulous purchases such as the MD Tributes then the Ortofon e-Q7 and finally the FX700.
I am just curious if you have heard the current FX850s and your comments & impressions of them. Thanks in advance. Cheers!
Haven't had a chance to try these - the last new JVC release I got my hands on was the FXD80.
Hi Joker
I'm curious more than anything. What would you think would be a good upgrade to the old westone 3? I've heard westone 2 (great apart from a lack of bass)klipsch x10, tf10. Was just looking for something a little more off the beaten path.
Listen to Rock, metal and audiobooks. The only thing is they must be excellent isolators as I use these at work (either out of a ipod classic or a sansa clip plus) to keep my self some what sane.
No real budget but lower the better.
I've gone through (in my head,no purchases) everything from the likes of the earsonics se6 universal, 1964 ears v6 universals (taxes put me off here) stagedivers 2 and 3 (afraid off too much bass in 3 and too little in 2), then I go nuts and start thinking about the unique melody mentor and roxanne (mentor unlikely and the roxanne just looks too big for my ears!).
Thanks
The W3 is pretty unique in signature. The 1964-V3 and V6-Stage do come to mind, albeit with the same reservations you have about the StageDivers - the V6-Stage is pretty flat in the bass region (a-la SD-2) while the V3 is quite bass-heavy (but slightly more balanced than the SD-3 nonetheless). Could be a case where neither one hits your goldilocks zone.
The rarely-mentioned Ultrasone IQ reminded me of the W3 in many ways - strong bass, strong treble, some dryness/analytical tendencies in the mids and treble, not bright despite treble energy, and so on. With some simple mods it actually sounds very good. Ditto on the discontinued Phonak PFE 232 - it's very similar, and doesn't require modding, but isolation is a little worse and the mids never sound quite as good.
Two more cheap(er) options I would consider trying: GR07 BE and DN-1000. Neither really channels the W3 but they're strong performers, especially considering the cost. Isolation could be better but it's not terrible.
Nope, and I already tried on multiple sources: phone, computer, etc
Edit: at the L-shaped plug, where the cable itself comes out, it seems a bit stretched/bent as if it was pulled out and then put back
The internal wire is most likely broken. If you have a soldering iron you can fix this by snipping off a bit of the cable and putting on a new plug.
Hi ljokerl,
Thanks for all your advice!!
I've been going through quite a few pages but I can't find anything that answer my issue: I quite enjoy the Momentum on ear and would like to find something similar in iems.....any suggestion (possibly at half the price of the MOE).
I have and enjoy the Sony MH1c. Unfortunately they keep slipping off my ears which makes it a bit tricky to listen to....
Thanks again for your suggestions!
MH1C would have been my first choice in that price range. Have you considered just getting new eartips for it instead? Foam tips should solve your problem.
If you go up to ~100-150 in price, there are a few options such as the Yamaha EPH-100 (bassier, but not hugely so). The Shure SE215 is another option that's less expensive and similar in signature. The Phonak 012, if you can find it, would also be a solid choice - not as bassy as the EPH-100, SE215, or MH1C but still smooth and warm-sounding, and very good overall. Great fit and comfort, too.
Hi,
I have the Hifiman RE-600 and love it. I am looking for another pair of universal IEMs. I prefer a balanced presentation with nice treble extension, good mid-range and deep accurate bass. Basically a slight V shaped sound signature.
What would your recommendation be for universal IEMs below $600? Customs are not an option for me.
Couple of options I would read up on:
Dunu DN-2000: hybrid earphone with a less v-shaped signature compared to the cheaper DN-1000 but still no lack of bass impact or treble. Relatively inexpensive at ~$315 and would make for a good RE-600 compliment IMO
EarSonics SM64: has deep bass and a warm tone, with strong mids and slightly relaxed treble. Not quite v-shaped, but it's halfway there. It's warmer than the RE-600 and would make for an interesting change. The Westone W40 is not too different, but has less deep bass emphasis and slightly darker tone overall
Lear LUF-4F: v-shaped quad-BA earphone. Has more bass than RE-600 and bright, crisp, extended treble with lots of upper midrange energy. Mids sound clearer than W40 (for example) despite v-shaped signature. There are two other versions as well, one with more bass and one with more treble.
Olasonic Flat-4 Nami: very clear-sounding earphones with a mildly v-shaped signature. Very tight bass and even brighter than LUF-4F (closer to the LUF-4C, which has emphasized treble).
