SebsG
- Jan 29, 2014
My ue600's should get here today. Now the wait..
It's not a review - just a quick short comparison. Anyway, no offence taken. I know that joker will be receiving them soon or received them already and that's why I'm asking him - not because I need someone to tell me whether what I hear is right but for the other members like you coz I know people will be waiting for someone like joker to greenlight them.
Well, I got ta' tell you.....they do have a good look to them. I took a look at several Chinese websites and it kind of reminded me of the "SoundMAGIC ES20" IEM's. It would be interesting to get these Philips just to compare both, since I do carry these in my batch of IEM's.
They're very solid, too! With a pretty wide soundstage.
I don't recall seeing these in Joker's list, though.
Here's a quick pick.....
.....So many red lights, we're all waiting for the green.
i think you should try memorex ie400 , i picked 4 , at various prices , lowest being $8 .
A friend of mine needs new iems for cycling. I know that it is dangerous, but he will use some anyways. So something that is not affected by wind and cable noise. Any recommendations?
SebsG, high volume is bad for your ears more so than drivers. You can replace your IEMs but you can't replace your ears
Lol, 50 - 75% is my max. I wanna know if that's bad. I should have specified what loud is for me
Which one wins in SQ Philips 3590 or monoprice 8320?
Joker, I want buy a JH13 Pro Freqphase, but I´m afraid of It sounds lean. Does sounds it more thinner than Philips SHE3580? For me, the sonorous body of SHE3580 is appropriate.
Could you also compare the JH13 Pro FP with SM3?
I´m thinking of buy the JH Roxanne instead of JH13 Pro FP, but I don´t know if it's worth...
Thank you!
Hello joker. What iem would you recommend that has good soundstage? I like a warm+sweet sound but soundstage is the top priority and isolation. My budget is limited to 70dollars. And I'm leaning towards t-peos d202(not the round cable), sony xba-1, meelec m9, tdk eb950. Or if you have any suggestions, that would be great. But i hope your suggestion are easy to find in the Philippines. Thanks!
Really? The philips tx2 is 40 bucks and has quite a bit better soundstage than the pistons and not just size-wise.
Btw, joker, did you get the tx1 and tx2 already?
what do you guys think about ath-ckx9 ?
Also, idk why, but the cable on my right ear won't stay over. This always happens with IEM's and it's kinda frustrating when I'm trying to sleep. Any ideas as the the cause? Probably my ear shape.
Sidenote: Are high volumes bad for the BA drivers? I want these to last a while so I am trying to baby them.
I have the CKX5. Supposedly the higher-end CKX models are tuned for more bass. The CKX5 already has more than enough bass for me. I really like the fit of these, though, it’s very secure in the ear.
