ljokerl
Portables Reviewerus Prolificus
- Mar 2, 2009
double post
Nah, I never liked the ER4. I loved it! Hence why I use the HF2 as my exclusive means on the go.
I was wondering.. since so many of our beloved companies have offers what iem would be a good partner for my gr07. meelec offers the cc51 for $36 and hisound the crystals for 50$. I am buying them with the possibility to use them for commuting and maybe running and sports. I guess the crystals build quality and comfort suits the situation better?
P.S has anyone tried the hisound small mp3players? the rocoo C and the amp3 m?
Also, if there is a very small light tear (not a hole ) in the part where the soft black part connects to the firm part in the Sony Hybrids, could if effect SQ?
Hey Joker did you change the picture of the ER4? I think you changed the score for sound too up to a 9.1.
Just jumping into IEMs and the HF5 have caught my eye. But, will I have problems getting these into my ears? Also, I mostly listen to EDM.
Thank you very much, but I have one more question, just so I can make this clear.
Your reccomending the M21/M31 over the M11+ for rap/hip-hop correct?
How about some R&B with T-pain?
Songs like this one?
I would like to be able to hear all the crisp vocals to some extent, but having great bass and an overall fun sound if possible.
Should the M31 be able to pull of sounding good on a song like above?
My IEM purchasing path was Brainwavz M1 -> M3 -> M2 -> Vsonic GR07.. The GR07 is by far my most favorite and completely blows the M3 and M1 out of the water from what I remember of them.. What I'm looking for is a pair with the clarity and response of the GR07s in the mids and highs with bass more in tune with the M2s but better overall quality.. The GR07 becomes uncomfortable fit wise after a while because my ears are a tad bit too small for the housing and it begins to dig into the bottom of my ear which is another reason I'd like an upgrade/sidegrade.. I can return the GR07 for 180 and can add 20-70 on top of it so if there's a pair at 250 or under that would give me what I'm looking for I'd like that.. The other option is an amp like the E6 with its bass boost on the GR07s.. The isolation on the GR07s is good enough as is the sound stage and separation but if any of that can be improved that would also be welcomed.. Thank you for any suggestions and if what I'm looking for is well above what I have to spend thanks for letting me know that as well and I'll try the amp route.. My portable source is my HTC G2 and my home setup is a Fiio E10.. I listen to the basics genre wise: hip hop, rock, pop
What about a slight downgrade in mids/highs but a good upgrade in bass? How do the Atrio MG7 or the MTPG compare? Those are the two that seem to be at least a little similar but with more bass.. But I haven't seen any comparisons to the GR07 since they are a different type of IEM.. Thank you so much for your answer
Joker, if you had the IE8(0) and the ACS T15 side by side for the same price (we get to buy the new IE80 for ~ € 200, which would be just as much as importing the ACS T15 from UK, shipping included), which would you choose?
Considering I like the presence of bass (but it shouldn't have to be bass monster) and appreciate details. But the most important part of the sound to me, is the "impact" - I don't only want to hear it, I want to feel it, I want to feel the energy, the drive. My music styles is almost 100% electronic (think Kraftwerk, Jarre, New Wave, and other kinds of synth pop..). Bass presence is as said important, but I wouldn't want the bloated one note doof that I get from my S4. Clarity is almost as important, and soundstage is probably the lest important part. I know this probably sounds like up the ACS alley - however, 2000 kr ($270, €200) for the new IE 80 sounds like an offer too good to let go?
As reference I found the RE-262 a little too "laid back" or something for my tastes. A little too mid centric perhaps? I wanted better bass response and a lot more treble, as I thought they sounded somewhat muffled to me..
Really what I'm looking for is a more fun IEM to listen to while at work since I recently purchased a nice pair of studio monitor headphones for the neutral response I wanted for house use.. The GR07 are amazing and filled both home/work needs but now that I don't use them at home while I'm out I want something that gets me moving and into the music.. I think what I really want is an improved M2 with enough clarity in the mids and highs that I didn't get with the M2s plus better bass response which is why I was looking at the golds and M7s.. Do those fit that? Also I need at least good isolation as my job has a lot of noise around me.. I also wanted to try and find something I could purchase off of amazon so just in case I don't like it I know I can trust in their return policy.. But if the FX500 are what I'm describing I'll look into those over the others.. Sorry for all the questions and I really appreciate the time it takes to answer them
Either the MG7 or the FX500. The MTPG is too excessive on bass. The MTPC could be a good candidate.
They sound nothing alike. The T15 is mostly flat, with maybe 1-2dB of lift in the sub-bass region. The IE8 has a large mid-bass lift. I don't think you will like the T15 if you expect enhanced bass in the conventional sense. There are tons of options that fall between the heavy bass emphasis of the IE8 and the flat response of the T15 - VSonic GR07 and JVC FXT90, for example. Reading your post I really don't think any bass below that of the FTX90 will satisfy you.
Just a question: If I did choose the IE80 path (assuming they're almost the same as IE8), would there be enough clarity, good treble, details and "energy" from it to make it a substantial upgrade from my Klipsch S4?
