I really, really enjoy the Tennmak Pro. As for the cable, I think it would work if the connections match. Worth a try!
I could be mistaken, but are the Tennmak Pros exact copies of Shure SE215?
That is what some have said. I have not heard the SE215's, though.
Ok. They do look really similar though, except for maybe the cable connectors.
Would appreciate if someone could chime in regarding how the Tennmark Pro sound...is it similar to SE215?
I have tried a friend's Shure 215s. The Tennmak (although priced around 21-25$, depending on where you get them from), offer a sound stage which is quite different.
He had to burn in the Shure's for quite some time, but the TM Pros sounded great right out of the box.
Also, AFAIK, the Shure's are single micro driver but the Tennmak are dual drivers (hence more and cleaner bass).
For me they are as good (or even better) in SQ and build quality.
You can find some reviews on the Tennmak here on head-fi as well.
Thanks,
CK
Hi guys, I'm new to the IEM game, I just got the Shure SE215 for $80, what do you guys reconmmand for upgrades to it.
Thanks for the input @Ckhurana
. Interesting, will have to give the Tennmak Pro a try then. Where's the best place to get them..AliExpress?
The SE215's bass is already enough for me, quite 'bloomy' & overwhelming sometimes. So if the dual drivers on the Tennmak Pro is able to give cleaner & more well controlled bass, then that's excellent.
My guess is that the bass on the Tennmak will be of better quality and the subbass on the SE215 doesn't reach very low (albeit mid bass is too much for me to on them) so the Tennmak will probably have deeper bass as well.
Anyway my Pros should be here in about a week so I'd guess we'll know for sure then
Great! Would appreciate if you could let us know your initial impression of the Tennmak Pro once yours arrive. I'm most interested in the shape & size of the earpiece housing. If they're 100% identical to the SE215 then my ears won't be too happy with them, but if they sound way better than the SE215 then maybe I'll take a risk on 'em.
Thanks for the input @Ckhurana . Interesting, will have to give the Tennmak Pro a try then. Where's the best place to get them..AliExpress?
I kind of like my SE215's with a couple of my sources but what fixed the bass for me was silver plated copperProbably will pick up the Tennmak Pro but waiting to hear Peter's impressions 1st(Not to mention I need another iem like and Eskimo needs a bag of ice)
Does that mean sonically? Because the tennmak is a dual dynamicThat is what some have said. I have not heard the SE215's, though.
