- Oct 31, 2010
+1
If you're looking for bass you should try HE-560
+1
IMO, the Alpha Dogs have better bass quantity and quality as compared to the HE-560!
Cute, have you sold your 560's yet? I would love to hear more about the 560's vs. The AlphaDog, please .
I love my ADs but hear things differently from gl1tch. With a well matched amp, Hd800s are a clear step up from ADs (and most everything else on the market) in resolution, detail, soundstage and bass quantity and quality. As they should be given the cost difference. Note that I spend time enjoying both of these excellent headphones just about every day.
The fact that ADs are such open, balanced and beautiful sounding closed headphones is what makes them so unique imo. Unless I have a totally quiet or empty house, they are my go to phone and are perfect for a bedside rig that won't drive your spouse / SO crazy due to sound leakage.
Still have both the HE-560 and Alpha Dogs....hard to compare an open vs closed HP, plus I have a tube amp plus two ss amps, and 8 different after market cables, both the Focus and Focus A pads for the 560. I will say the AD with a cable upgrade comes close to the LCD3. I like them both and if I had to chose which one.....well, I couldn't....nice to have them both for different listening options!
Cute, what cable are you using with your Alpha Dogs? I am looking at a Norne, customized for bot single ended and balanced.
^Cute, Trevor seems like a very capable designer, readily suggested custom termination solutions so I can use one HP cable single ended and balanced. Great sound would also be a plus. If you had only one other headphone to complement your Alpha Dogs, which would it be and why? Thanks for sharing your experience!
I was planning on getting a custom cable here for the Alpha Dogs:
http://www.bestintheversecables.com/shop/5htb09jwlksk5j48d36l1xdzdunpnj
The one who makes those also visits Reddit so you can probably contact him about more customized requests.
I talked to him for a bit and he's a bit backed up on his production but they're a good price.
They are nice looking cables with quality workmanship, but no mention of the most important thing.......the wire that is used! I would look for the latest cutting edge technology, Type 4 or Type 6 Litz, It doesn't corrode, and the sound is phenomenal, aka Norne Vanquish, Double Helix Cables!
HE-560, price for performance is very good, open vs AD closed, both fairly neutral other than that!
