Problem with pad rolling is if they are glued/ must be glued down, that makes switching pads around difficult.
Actually, not really. Headphone pads don't need to be very strongly secured to the headphone, especially if you wear them with any amount of clamp on your head. And you probably do, because you don't want your headphones to be so loose they fall off. I'm going to definitely try some different pads myself. I see the openings are oval shaped which is great, but I wonder how much free space my ears will have. I've always preferred velour because I think it feels better.
What I mean by that, with a little careful finagling, you can try the sound on a pair of pads without actually attaching them.
The problem with these being glued down, from what I have read in this thread is they are glued down
excessively. I wonder how hard the pads are to remove in a manner that would let you re-attach them if you ended up deciding to use them after trying others.
There are also options such as using velcro tape, and for an even more robust but still interchangable option, 3m makes a sticker that is strong enough to hold picture frames that you apply to both sides and it works/looks like a much stronger version of velcro. You could padroll to your hearts content using that style of tape and the connection is so secure they would NEVER fall off.
I'm not sure if I want to cancel my order or not, but I'm really disappointed in the cable connection. It's been beaten to death in this thread but mmcx does not look stable to me at all, and I also don't understand why they would include such a short cable, especially one with an unthreaded 90 degree angle minijack.
I think I have purchased about 20 pairs of headphones in my life, and the only kind of headphones that did not come with a 1/8 to 1/4 adapter were IEM's/earbuds. I
probably have an adapter that will work, but I know most of them won't. 90 degree angle connector is also a little disappointing but in reality it doesn't bother me so much.
The storage case looks nic
e.
And they apparently smell great, so all complaints about the mmcx connectors are forgiven.
