The Monkey
Monkey See, Monkey DAC
A really sick dud
- Oct 28, 2004
Good stuff ASR. I want a bhse.
Convenience is also the reason why my BHSE is mostly neglected these days as the KGSS is just so easy to live with.
Interesting. What is the inconvenience? Once you've reconciled yourself to the heat output and power dissipation, isn't it a matter of erm, just switching it on?
Am I missing something?
My problem is that I work way too much so there is no time for extended listening sessions. Leaving tube amps on while unattended is a very, very bad idea in my book and repeated thermal cycles are also not a good idea for the tubes. The KGSS on the other hand I can just turn on when I get home and turn off when ever I stop using it. Mine does get pretty warm though since the amp is stacked on top of the PSU with rather small slots to suck in cool air. Still that massive aluminum chassis (about 10kg) acts as a nice heatsink...
As for the HE90, pffft....Anything the HE90 can do the SR-Omega does better and the SR-007 is better still.
Btw. It was a lot of fun to read the Mk1 and modded SR-007A comparisons. My main set these days is a modified 007A though the mods are rather different now.
Also the pricey tubes in the BH require maintenance and if one "heads south",
it can cause much hate and discontent, possibly frying those high-end Stax cans
or other parts of the amp. I have no direct experience with this,
and have not heard anything negative with Justin's latest BHSE design.
The older BH designs are legendary for "grenading".
When running right, they do herald the impeccable TOTL stat sound.
The solid state designs (KGSS AND KGSSHV) are not prone to these type of fireworks.
The KGSS did indeed replace my old 717 in this role. Both are lovely amps but Stax went a bit too far in butchering the KGSS design for my liking (the 717 is just a KGSS built under license) plus the KGSS was a bit cheaper for me as it was mostly recycled ...
What kind of maintenance do the BHSE tubes require?
Could you please provide any links to DIY BHes destroying headphones?
