Br777
- Feb 2, 2010
ya know what would be really cool - if digizoid made a box, that was not an amp, but only utilized their "subwoofer" tech. this way you could get all the benefits of awesome bass, while still using your high end portable gear.. how cool would that be.. sr71B, lcd2, and some added sub-bass a-la-ampless ZO.. i would buy one of those in a heartbeat!!!!
Well, as a matter of fact, with ZO v2, you will be able to do just that! You can use it as a sort of "pre-amp", which gives you the benefits of our technology, and the flexibility to couple it with a higher power output amp! And... it will still be powerful enough to use standalone for portable listening!!
btw... some of the perceived level increase you hear with ZO is not due to a boost in gain, but actually is a side effect of the technology!
can the digizoid create something with their technology that would pair with any amps?
what i mean is...can they create a newer ZO without the use of (zo's own amping) amping? so that we can pair the ZO with our own chosen amps?
a new zo without the built in amp, but a zo with its technology.
so that, when a person chooses to add an amp with his set up, it wouldn't be called double amping. (zo + chosen amp)
^ this...
