You're right. I was not trying to spread misinformation. I have no opinions on tube amps either way because I have no experience with them. Review edited above to reflect this. All comments on amps are for solid state and readers should assume such.
Yeah, he is way off base here. I have a $100 DIY tube amp that I can make sound 10 different ways depending on the tubes and opamps I put in it.
Double blind A/B yourself with my $50 amp versus your favorite $1,000 amp and then come back and post results. As to the allegation that I am overestimating the performance, I'll just say that I owned a Meier Corda. I know what a good amp sounds like. Specifically, a good amp sounds like nothing. It provides power with a low noise floor. My $50 amp does everything the expensive amp does.
The hardest thing to drive properly without distortion is bass. I have 3 "neutral" headphone amps here. The Asus Xonar has a built in amp, the E5 and the Headamp4. There is no "color" distinction between any of them. According to your logic, I'm lacking the "power to drive." If that's true, you should also realize that the Headamp4 is MUCH more powerful than the E5, correct? So, then the Headamp4 should be head and shoulders above the E5 in sound as well, right?
It isn't. It's exactly the same. The only difference is how far I can drive volume levels. The E5 doesn't go that far. The Headamp4 goes way beyond normal listening levels. If that weren't enough, my signal is being amplified TWICE. I have the ASUS Xonar and the Headamp4 on one chain. One amp, three amps, it doesn't matter: they all sound the same.
Take the Pepsi challenge and blind A/B yourself. Otherwise, see my philosophy above.
You're greatly overestimating the performance of something like the ART amp you reviewed. I'm surprised no one brought it to your attention, but these are the specs:
