nephilim
- Aug 30, 2014
Does the LPS not have that power? and in summary I can not use the ECC31 with 6SN7 Adapters directly on the MZ2 with LPS? I dont want to go through the hassle of using these special adapters and more power supplies, but I have the ECC31 with me which I'd love to try without risking any damage to anything.
The LPS might provide sufficient power but the ZOTL's circuit (including the fuse) is designed for the lower current requirements of the 6SN7 and as far as I know the ECC31 will at least require a higher rated fuse. But then I would not mess around with it because I do not understand if there are further restrictions down the road. So I went with the adapters mentioned above which feed heater pins 7 & 8 from an external source. On this basis I can use other tubes with their specific adapters (FDD20, ECC31, C3gS, etc).
Two notes:
1) Some adapters are too bulky for the restricted space inside the ZOTL -> bigger effort required to make a custom top with sockets
2) The non-6SN7 tubes will most likely not run in their optimal configuration. I have no idea if that will lead to issues with the tubes or the amp. So far I am very happy that everything is running w/o problems but in case one day the amp is a black molten mass, I will certainly not blame it on Will
