I thought that he only meant that for the HE6. I plugged in my LFF Code X (HE5) as well. They are lets say equivalent to HE500 power requirements wise and get too loud on the LC even under half way on the volume knob and the MZ2 cant even power these without getting distorted? Then I plugged in my Omnis and same results. Why do I keep reading these have enough power for most headphones and what not?
I read enough comparisons between the LC and MZ2 mentioning how MZ2 trumps the LC in all possible ways, without anyone mentioning that these just dont have the power for many headphones, and I assumed specs dont say everything about amps. I might be missing something completely or these are maybe just made for very easy to drive headphones only.
Jozurr, apologies about not addressing more of your questions more clearly. It's been very busy around here.
The HE-5 is also a hard to drive headphone. The HE-500 is designed to be more sensitive than the HE5 I have limited experience with, but recently used one with a MicroZOTL2 and found I could go quite loud around 1 o'clock on the pot, and had no distortion. I've listened to several different Omnis with the MicroZOTL2 and never heard distortion, nor reports of distortion. Zach of ZMF, who makes the Omni, has a MicroZOTL2 and has never mentioned distortion.
An amp needs a power supply. You can't compare the MicroZOTL2 "with and without" the LPS, you can compare it with the LTA LPS and with a different power supply. The stock model we sell comes with a smaller, lower-quality switching power supply. There are many options for power supplies you could switch out.
The LC puts out more power than the MicroZOTL2. The power output of an amplifier is not equivalent to the quality of the amplifier. I don't think anyone has claimed, nor we would claim, that the MicroZOTL2 is a good amp to listen to the HE6, HE5, or any modified version of either.
Some people think the MicroZOTL2 makes the HD-650 sound better than any amp they've tried. Some (fewer) people think it doesn't power them well enough.
If you have the locking jack, the preamp output will still be active when your headphones are plugged in, though they'll share power. If only an adapter is plugged in, I don't imagine you'll be losing any power, though the signal path probably won't be as pure. We recently made available a closed circuit jack that disconnects the speaker and preamp outputs when headphones are plugged in.
If using the MicroZOTL2 as a preamp with a DC coupled Solid-state amp,
you must turn on the MZ2 BEFORE the amp and turn it off AFTER the amp. Otherwise the turn on and turn off transients can be amplified and can be dangerous for your speakers and your power amp. We are developing an ideal way to do protection but it won't be available for a while, in a future model. The current MicroZOTL2's preamp capabilities were put in as an afterthought that has turned out to be very good, but unfortunately it is operated in the most basic way and must be operated carefully with DC-coupled power amps.
There is also the possibility that something is malfunctioning with your amp, if you're hearing all of this distortion. If you'd like to contact me via PM or via the email on our website, we could troubleshoot that with you.
