But in spite of this difference neither of them can compete with a pair of NEVZ 6C2C/6S2S when it comes to tone and presentation with ATS25.In my opinion the standard 6N6P version sounds better than EH 6N30Pi. The tone is more natural and the picture gets more pixels. I'm using it with ATS25 that need to cook.
McChanson amps tube rolling thread
Deleeh
I have only one and only one 12ax7 and that is an Amperex with white paint on the top pointed end. It is claimed that white paint is surgical grade and have divine powers.
Believe it or not, I have not tried soldering despite Eric asking me to do it all the time. I will have to buy solder irons and get my hands on it. Replacing the caps on the Super Ultimate is easier because there is more room.
This is the Russian FT3. Perhaps paint it gold? Btw I will be comparing this with the Duelund and Vcap cutf when Matt's amp is ready. There might be a huge upset !
The caps are actually easy to solder.
You'd be surprised how easy it actually is once you get the hang of it.
With the Junior it actually went quite well, only the cap itself was a bit bigger than everything else, but it worked.
A good soldering iron where you can set the temperature would be good.
The rest you actually learn by doing.
Simple exercises such as tinning and connecting cables are actually these things, and you'll see the rest when you have to solder in the housing.
As soon as the solder is liquid, you stop just before and connect it, that's actually the trick.
I'm looking forward to the one you're going to fit, but I don't think it will be on a par with the Vcap CuTF.
It might still be missing a bit.
I'm looking forward to seeing how the Duelund performs.
You would also benefit from having a good solder sucker, solder remover.The caps are actually easy to solder.
UntilThen
- Jun 16, 2015
I’m at the Studio
And I’m seeing 3 caps. Mundorf is not in the picture because it is in the amp.
Perhaps I should ask Eric to put Duelund and Vcap in mine.
UntilThen
- Jun 16, 2015
UntilThen
- Jun 16, 2015
Deleeh
I’m at the Studio
I was really lucky with the CuTf, although it is quite heavy in terms of weight.
I had to connect it to the Mundorf so that it didn't hang down.
A nice picture of the caps, the Audio Note copper is still missing.
The Mc Chanson badge also looks very good.
Question for my fine fellow UltimatE'rs: Do 807 and ATS25 tubes use same adapter? Is the latter considered a better quality version of the former?
UntilThen
- Jun 16, 2015
Yes and yes.
GEC 807 ATS25 is claimed to be the premium 807 Made in England in the 1940s. There is another version GEC 807 VT60 which is also a premium 807. I have both since 2 weeks ago.
Many rate this tube as sweet sound like the 300b. Me? I just think they are great power tubes without putting too much hype on it. and I mean great not good.
Thank you Matt, as always!Yes and yes.
UntilThen
- Jun 16, 2015
I'm home and very excited. Had a quick listen of the FT3 at Eric's place after it was installed. This is my cup of tea or coffee. Clear, sweet and stirling is what comes to mind. Similar wow moments like when I first listen to the Vcap cutf. Now to let it burn in while I enjoy it.
It's not an easy fit getting the FT3 in the space allocated to Miflex because FT3 is longer. Some connections has to be pull loose to get it in and then resolder everything. Glad I wasn't doing it. Eric wrap both ends of the FT3 with red tape and it look very nice but the purpose is not to make it look nice. It's to prevent contact with other points.
UntilThen
- Jun 16, 2015
Eric's thoughts on the 6N6P tube.
The 6N6P is the 6H6Pi in Russian words... You have the 6H30Pi which is the same as 6H6Pi if not better. ( I do have Russian 6H6Pi but not included in the lot I pass to you ).
Zachi's whispEr in dual tube mode has this 6H6P in the middle ( the other two on the sides are the 6S45P. ... see picture
UntilThen
- Jun 16, 2015
You're welcome as always !
If you're going to buy the GEC 807 ATS25, you might as well get the ITT 5b/254m and adapters. They are pretty special.
UntilThen
- Jun 16, 2015
Matt just told me the price for the Duelund and Vcap caps. I always thought that Dueland would be more expensive but it seems Vcap is the real money burner.
Duelund CAST Cu-Ag Hybrid 0.47 uf 630VDC pair - US$280
Vcap Cutf - nearly US$600
Duelund and Vcap are featured in this review.
https://www.humblehomemadehifi.com/Cap.html
Russian FT3 - US$38.50
Review found here - https://www.enjoythemusic.com/diy/0708/capacitor3.htm
I realised that I will not have 200 hours on the Duelund and Vcap but probably 100 hours by the time I do the comparison. Under the circumstances, that will have to do.
I will disregard those reviews and form my own opinion after my evaluation in Super Ultimates.
UntilThen
- Jun 16, 2015
While at Eric's place, I didn't realise that he's so busy. There are 4 amps in construction phase. A silver Destiny with IT and Silk transfo, a KT150 amp, a MIni Ultimate and a Junior wooden Ultimate. 2 others are waiting for Silk transformers - Hai's Supreme and Matt's Super Ultimate.
Incredible that as a one man show he does all these and he has time to change my caps and for a bit of chit chat.
