lowrider007
The M-Stage has a 5 ohm output impedance. I don't think it is ideal with 32 ohm headphones. Ideally the headphone impedance to output impedance ratio should be 8:1. If you are going to use a lot of 32 ohm headphones, I would look at an amp with less than a 2 ohm output impedance. I have noticed that my M-Stage tends to be noisier with 32 ohm headphones. With my K7XX I hear no noise and a perfectly black background.
Since you are looking for a new amp, maybe you could keep the M-Stage for use with your AKG's and get something with a lower output impedance with your low resistance headphones. 32 ohm headphones typically don't require that much power so a super high powered/expensive amp isn't necessary.
Thanks, well I'm definitely keeping the HPA-1 for my AKG's, I'm currently building a wooden stand for it to sit in sideways.
Someone is selling a JDS Labs Element on my forum, how do you think that would fair with more sensitive cans?
