"The bass has better extension...it is much less loose sounding than the default OPA2134." (now you have my complete attention).
I appreciate the ear-friendliness of the stock HPA-1. It's the opposite of bright, also a compact & effective system pre-amp, once the woeful volume knob is replaced w/one that can easily be seen. But it was easy to tell that the stock bass is somewhat loose & "boomy." One of my favorite inexpensive Chinese closed back headphones, the Yenona Adapter Free DJ model, sounded distinctly boomy on the HPA-1, but not on 2 other SS amps (Burson Soloist amp/preamp; and Lake People G109-A).
Your description of the LME49990 intrigues me. I may have to try this. But how exactly do you buy this opamp in such a way that it installs properly in the HPA-1? Does the stock opamp come configured properly for the HPA-1, or do you have to buy 2 set onto an adapter, as I did for the OPA627?
And where did you buy yours? Obviously I want to avoid fakes, which are very common, as @leeperry pointed out.
You can purchase from this guy on EBAY. They are definitely authentic. Yes, it comes with two on the adapter. I think you will be impressed. The LME49990 is a far better sounding opamp than the OPA2134. There is no question about it. It is so much more refined, articulate, accurate, and detailed. I will be shocked if you come away unimpressed.
http://www.ebay.com/itm/1PC-DUAL-SOIC-LME49990-OP-AMP-MODULE-DIP8-/201562948955?hash=item2eee16855b:g:A9QAAOSw6oBXEnVs
