Hey guys,
From what I have been able to dig up so far, the differences between the Marantz CD5003 and the CD5001 are:
The 5003 has:
1. A newly designed metal/fiberglass chassis.
2. A slightly different drive mechanism.
3. A detachable power cord.
4. HDAM S2 modules. [The 5001 does NOT use HDAM modules at all].
[It will be interesting to see if the HDAM S2 modules will make the 5003 sound any better than the 5001].
The CD5003 still uses the same Cirrus Logic CS4392 DAC as the 5001, which is sort of a disappointment, considering that the CD6002, [available in Europe], uses the latest Cirrus Logic CS4398 DAC.
I would like to see Marantz design an "all out" CD ONLY player that uses the same technology as the upcoming SA8003 SACD/CD player, such as:
Rigid design with double-layered bottom chassis, Zero impedance copper ground plate, audiophile grade power supply with toroidal transformer, Zylon Loader, and Cirrus Logic CS4398 DAC, and STILL include the HDAM S2 modules...Dream on!
Update:
I bought and received another Marantz CD5001 from Crutchfield last week.
Wow, I forgot just how good this little CD player sounds!
For some reason, I think this new 5001 unit sounds better than the one I had last year! It does not sound as bright or as thin as that unit did, and sounds closer to my 8001. The numbers on the display are also a tad bit smaller than the unit I had 14 months ago.
My 8001 still sounds slightly more refined, with slightly better resolution, has a tad more sense of space, and is alittle warmer than the 5001, and maybe has better bass using cd's, but I STILL think the 5001 is slightly more extended on top, and sounds slightly livelier than the 8001.
But overall, I feel that the differences are relatively small, and the 5001 is a much better bargain, especially if you listen almost exclusively to CD's like I do.
The main reason I bought the 5001 again, was so I could compare it head-to-head with the CD5003.
I also preordered a Marantz CD5003 from Onecall last night.
They said they did not know for sure when their first shipment of these players would arrive.
I will post impressions of the CD5003, and how it compares to the CD5001, whenever I do receive it.
I will also compare their headphone jacks with a pair of Sennheiser HD650's, to see if the headphone jack output on the 5003 is worse, the same, or better than the one on the 5001.
