martin vegas
- Nov 9, 2013
I know this isn't anything to do with headphones..they are bringing gulf of oman metro and Caspian border back in bf4!
If its for FPS mainly, the ADG1 or AD700X are pretty much a guaranteed success.
The AD700X are the same as ATH-AD700 but better i guess ? And ADG1 and AD700x are basically equal ? Guess ill go with the AD700x then
The AD700x doesn't have a mic.
One last thing, you said the only Xonar thats good enough for K702 is the STX. Is there any soundcards like creative or any other brand that has better soundcards then the STX for the k702 ?
One last thing, you said the only Xonar that's good enough for K702 is the STX. Is there any sound cards like creative or any other brand that has better sound cards then the STX for the k702 ?
I'm pretty sure the entire Sound Blaster Z-series lineup has the same headphone amp chip used in the Xonar Essence ST(X)...and the FiiO E9, for that matter.
Still, as others have said, I'd recommend getting an external amp if that's what your headphones want. You don't want to replace your sound card every time you need to upgrade amps now, do you?
So, I just opened the replacement iCAN that arrived yesterday and all is not well with this unit, either. Everything works as it should, except for the damn volume knob. It is somewhat loose and the base scrapes against its surface every time I turn it. This causes a static noise whenever I try to adjust the volume; and the physical scraping when I do so just makes me cringe.
I contacted Avatar Acoustics and they're looking to see if I can get a different product as this is my second time having an issue with the iCAN. I made sure to complain about having to come out of my pocket to ship back, yet, another defective unit when they are supposed to be pretty much "bulletproof" according to the person I spoke to.
Glad I decided to check it out before posting a classified. I was going to sell it unopened... YIKES!
