how do u find wire part of the cable? im sure it was the M6's i had before and i just couldnt get used to the memory wire so i cut it out.
Both cables are clear and let you see the internal cables (which are isolated individually), although they have different feel outside and different isolation material on the individual cables (one's are chrome, the others are white).
From outside to inside, there are many layers to the headphones one can distinguish:
1. The memory wire plastic layer (clear, only covers memory wire then ends)
2. The steel memory wire that sits in between 1. and 3.
3. The MAIN plastic/rubbery layer, clear in both cables, which covers individual internal cables (and mostly shields from microphonics)
4. Individual cable layers, chrome/white depending on the cable. These are opaque and you can't see past them
Since they're both clear on the outer memory wire and MAIN layers, you can just remove the memory wire plastic layer completely with a sharp razor (carefully not to damage the MAIN layer), pull the memory apart from the cable so you can cut it easily (e.g. with a nail cutter or precision pliers).
If you've cut the M6 this should be a similar process: the cables are pretty much the same (except from the redesigned T junction and the fact they are detachable from the earpieces). Now you have the added pro that if you mess up the process, you don't blow the entire set and can just buy another cable separately!
