mmerrill99
Member of the Trade: M2 Tech
- Mar 2, 2006
can I know what Thomas indicated "external + and - supply" are actually going into the 3.3V regulator ?
Which means just ground the enable pin, remove the regulator (optional) and supply 'another' 3.3V to the regulator right
Yes those annotated connection points are +3.3V & ground connection points.
You will find grounding the enable pin to be quiet difficult - easier to remove the reg altogether BUT I'm suggesting NOT to do this at all, just do the clock mod as Regal has shown.
