Lotoo PAW Gold Touch - Touchscreen, 4.4mm Bal, USB DAC, Bluetooth
Nov 3, 2023 at 2:41 AM Post #3,421 of 3,540
Nov 14, 2023 at 3:48 PM Post #3,422 of 3,540
Looking for a bit of EQ advice...
At times I find the treble area on my LPGT Ti a bit bright regarding cymbals and piano and was wondering what frequency range should I be looking at to lower and by how much and what width of Q? I have messed about in the 6000-7000 range reducing buy 2-3dB but I honestly don't really know what I'm doing... Many Thanks.
Nov 14, 2023 at 10:49 PM Post #3,423 of 3,540
Lotoo has a nice PMEQ guide you can find under Q1 here: https://www.lotoo.cn/english/bottom/Service/FAQ/
Also, this well known FreqChart is very useful:
Nov 15, 2023 at 10:20 AM Post #3,424 of 3,540
Much Appreciated man 👍 According to that chart, I might not be too far away by reducing the 6-7k range for cymbal edge/zing then? Also will have a play about in the 6-10k range as well while I'm at it...
I must say, I hold your reviews in very high regard and really enjoy them and the details you go into, so Thank you for that 👍
Nov 21, 2023 at 6:06 PM Post #3,425 of 3,540
I still use this beautiful DAP daily.
Nov 22, 2023 at 10:47 AM Post #3,426 of 3,540
Same here! :)
Last week I also picked up an extra leather 'coat' for my LPGT...
The only thing that worries me a bit for the future is that at some point (still going strong atm) the battery has to be replaced :thinking:
Does anybody over here already has experience with that? I think Lotoo can send a new one and that it can be replaced by yourself that way?
Thanks in advance for any information on that...
Nov 23, 2023 at 8:12 AM Post #3,427 of 3,540
Check out AutoEQ: https://github.com/jaakkopasanen/AutoEq
I bought the TI because of the parametric eq.
Nov 23, 2023 at 8:31 AM Post #3,428 of 3,540
Same here! :)
I know in the USA, Musicteck can send it to China for service, including battery replacement.
Nov 24, 2023 at 9:38 PM Post #3,432 of 3,540
Nov 25, 2023 at 1:47 PM Post #3,435 of 3,540
Mest OG & Mest MKII. These along with the LPGT Ti and it can be a little too hot in the treble for me at times, especially cymbals and piano.
For the MKII look here: https://github.com/jaakkopasanen/Au...ts/crinacle/711 in-ear/Unique Melody MEST Mk2
The first five filters should work
Keep in mind that the Lotoo can not use the Q higher than 1. E.g. in filter 4 you use Q1 instad of 1,12.
To set these, go to settings->EQ->PMEQ->list on the right corner and then NEW.
When you set the type choos BPF for every band.
