Snake
- Nov 20, 2003
I'm short on time but I think I can add some comments here in answer:
You borrowed a 404/313 combo. If the combo was brand new then for sure the sound changed during the 10 days, for the 404's (and to a lesser extent the 313 amp) have a very extended break-in period.
If the 404/313 combo was not new, but had not been used for quite a while, then you experience the (more subtle) sound change of "charge up".
If the 404/313 combo was not new, and had been used quite a bit prior to your borrowing the system...then you, well, got used to them psychoacoustically. But then again it simple might be "Where you came from" in order to get used to "Where you were going", and what seemed bright at the beginning was only the dramatic change of something so forward, coming from something that (apparently) was "recessed".
The S/S vs tube Stax amp debate rages on. If you like the forward sound of Stax the tubes are meant to mellow that, and recess it. Different strokes. Tube rolling is said to help - but I also assume some warm up and charge up / stabilization of the 006T is necessary, as well. Again, can be purely psychoacoustic, as you came from "forward" 313 and went "darker" with the 006T...and didn't like it.
Originally Posted by Paul L May I ask two or three questions all related on-topic I hope: 3. I borrowed an SR-404 (but have not heard the SR-303) with the SRM-313 and intensely disliked the brightness but it calmed down after a couple of days and during the 10-day stay seemed to get better and better. I then borrowed the SRM-006T but only had 3 days as I would be away and I could not get into the amp enough. Too soft and details masked, it seemed to lack the speed, bite and dynamics of the SRM-313 and I am a tube afficianado so it's not an inherent inability on my part to enjoy tube gear when it's done well (IMHO of course). Given the price differential I was really surprised but it has now been suggested to me that I will not have heard the 006T properly as it also takes 7 to 10 days to really come alive. Is this true? |
