Giogio
Bluetooth Guru
- Nov 13, 2014
With quite a lot of hours listening now and some A/B comparisons on a number of varied test tracks I feel my initial impressions were pretty justified. Soundstage is definitely smaller on the AKG'S probably due to the shorter distance between ear and driver (one of the reasons the UE9000 look so goofy on my head-they stick out so far!) Bass is much tighter and less boomy on the AKG'S but is still more than adequate (how anyone could describe them as bass light is quite bewildering to me?) The only feasible explanation I can come up with is fit which like the K550's is essential for decent bass response. The treble and detail retrieval at the top end is superior to the UE9000 but this comes at a bit of a cost in the midrange. A good example if this would be Adele's vocals which sound a bit flat and one dimensional with the AKG'S in comparison to the UE9000 on which every breath and sinew of her vocal chords seem evident (More like listening to her sing live in a small intimate gig than hearing a recording. This wasn't apparent with all vocals though. The Kings of Leon "pickup truck" seemed to benefit from the higher resolution at the top end with the subtle cracks and raspiness of his voice. Anyway, I'm definitely considering these as a replacement to my UE9000 at the moment. Watch this space.
Edit: Just a couple of other things I forgot in my original post. The AKG'S sound almost the same when wired which is not true of the UE9000 which are like two different headphones imo. This has been observed as a positive by many UE9000 users as the sound wired is described as more audiophile (ie to have a flatter frequency response) However, to me listening wired to Bluetooth headphones seems to invalidate the whole reason for buying them (in my case on the go convenience). I suppose if they were your only headphones it might be nice to listen wored through an amp at home for a different experience. The controls on the UE9000 are also superior to the AKG as they operate perfectly with my Android phone including double and triple click to forward and backward skip tracks. The AKG do not have this feature which means taking out your phone to skip track (a major oversight on AKG'S part if you ask me) I also miss the listen over feature of the UE9000 which pauses the music and opens the mics at the press of a button in order to hear a person speaking. WhY more headphone manufacturers don't include this evades me as I find it a right pita to remove the headphones or pause the music when someone talks to you.
I have described them as one of the more bass lacking BT headphones on the market.
I may be a bit basshead.
Or may have been influenced by the other BT Headphones I was comparing them with, side by side.
The UE, I think, I got them later, so I do not think I have compared them side by side with the AKG, but the Fidelio M2BT yes for sure.
And the Fidelio I have compared them side by side with the UE and found them almost identical sounding, almost a clone of the UE, but with more highs (which are not of the quality of the AKG anyway).
Maybe the bass of the Fidelio is a tiny bit less powerful than the UE, eventually.
So, having the Fidelio (or UE) side by side with the AKG, I felt that the AKG had no bass at all.
I suppose that it may also depend on which music you listen to?
DO you test them with Techno, EDM, Heavy bassed Hip Hop, Dubstep, Hard Style?
Because when I want to test headphones on the low frequencies I use mostly that kind of music, and I felt that listening to that kind of bass oriented music with the Akg was like reading a recipe when you are hungry.
I had to imagine the bass, I could not FEEL it.
So, I never said the AKG are bad.
But the first thing I have thought when you wanted them as replacement for the UE was that you were trying to replace a pornostar with a shy teacher of history, and I was afraid you could not enjoy.
Or, on another kind of example, you were trying to replace pizza with sushi.
Both are good, but, they have just nothing to do with each other and when I crave for pizza I cannot be satisfied with sushi.
So, you are surpised that anybody could describe the AKG as bass lacking.
I am surprised that you can seriously find them a substitute of the completely different sounding UE9000.
SO I am curious now: which music do you listen to, and, do you tend to leave the EQ flat, or do you boost something?
