saisunil
Member of the Trade: Care Audio
- Sep 7, 2004
Hi,
I have had Live Wires (LW) for about 3 years now ... I liked them in the beginning but then I found then unengaging, unmusical, perhaps a bit congested, lacking air, a bit forward ... they sat in a closet for the most part.
So, per the previous business owner and manager's recommendation, I had them drill a hole / vent ... now there is no isolation -- so I don't like them any better than before.
The question is how to improve the sound ...
1. I will need to close the hole / vent - to help them regain their isolation - critical for bass.
2. Does recabling help, and worthwhile investment?
3. Are there other options to improve sound from them - other than buying the new custom $1100 phones
Thanks in advance ...
Regards
Sunil.
Regards
Sunil.
