gibosi
- Oct 18, 2012
I have a quartet of Siemens C3Gs, two bought NOS around 2 years ago and used about 200 hours, two used, and these are terrific driver tubes. I do not know about Telefunken or another brand C3Gs, but I suspect there is little difference between them. All were made in the sixties, or early seventies, under a strict West German, mil spec requirement typical of cold war for undeground telephone signal amplifiers that not only will survive a nuclear EMF pulse, but will amplify and forward even the tiniest communication signal, with utmost fidelity, and last a lifetime...cost no object, this class of tubes were designed to perform, with the very best and very expensive exotic metals, a Thorium alloy (I think) to absorb oxygen atoms inside the tube to preserve absolute vacuum...an all out assault to design a super reliable hybrid pentode/triode audio amplification tube. The specs of the C3G are unmatched, transconductance is enormous, something to expect in a tube designed to amplify weak signals reliably...this in itself does not relate necesarily to sound quality, but it does in the C3Gs. And power, dynamics, bandwidth, they will reveal ruthlessly the limitations of your power tubes. For example, 6SN7G double triodes were a clear step ahead over the stock tubes in my LD MKIII, and the C3Gs make them sing clear and loud, the differences just jump out, only a few were up to the task. I went all out to mod my little preamp to accept the mighty 6AS7G big bottles, and after that even the best 6SN7Gs sounded small, limited, restricted. The C3Gs clearly had the power and the amperes to control the big ones solidly, superior dynamics, fast, tight bass and a soundstage to die for... and the little thing is working as a preamp driving 2 mono SS NAD Amps. Extremely powerful as a Pre, I learned to set the NADs at about 1/4 output... Cheers to all !
I will grant you that in the LD, the C3g is about as good as it can get. But with all due respect.....
First it is important to remember that the LD was designed around the 6AK5, strapped to operate as a triode. If you put a 6SN7 into a circuit designed for a 6AK5, it simply cannot sound its best. The bias is too far from optimal. Fortunately for LD owners, a C3g, strapped to operate as a triode, is a much better fit, and yes, it does sound very good. However, in an amp designed to run 6SN7, I can assure you that the best 6SN7's do not sound "small, limited, restricted." I find them to be just as good as the C3g, but different.
Second, there is this myth that the C3g has been engineered to such high specifications that it is virtually transparent and doesn't have it's own sound. In my experience, this is not true. Tubes manufactured in different factories sound different. And further, tubes manufactured in the same factory, but at different times, sound different. I have Lorenz and Siemens C3g, and I assure you that they really do sound significantly different.
And third, yes, operated as a pentode, the engineering specifications of the C3g are among the very best of any vacuum tube ever manufactured. However, when it is operated as a strapped triode, the specifications are about the same as a 6SN7. This alone is a major engineering feat. Most pentodes, strapped as triodes, have relatively high levels of distortion and are not very linear, for example, the 6AK5. So again, while this is a major accomplishment, in the end, you have a "C3g triode" that compares well to a 6SN7. But in terms of specifications, if compared to an ultra-linear, low distortion double triode, such as an E80CC, a strapped C3g is really nothing to brag about.
I should point out that my amp is designed from the ground up to run either a pair of C3g or a single 6SN7, so it is very easy for me to compare them with everything else being equal.
So again, in an LD, the strapped C3g is perhaps among the very best, if not the best. But given that, it is simply not possible to extrapolate beyond the LD and come to any meaningful conclusions.
Cheers
