gibosi
- Oct 18, 2012
Found the information for the current draw of the EF91 and EF92 families of tubes. These tubes are recommended for use in the Little Dot MKIII. Here are the values:
The EF91 draws significantly more current (300mA) compared to the EF92 (200mA) and EF95 (175mA) families. (The source is post #2 on this blog!)
Am I correct that with a design parameter of 300mA current draw the LD should be able to handle 6AS7 tubes?
There are essentially two circuits. One to supply current to the heaters and the other to supply current to actually run the amp. The values quoted above refer to the heater circuit. For the 6AS7, you are using an external heater power supply to provide 2.5 amps to heat the heaters. What is burning up resisters and perhaps killing transformers involves the other circuit. And again, the LD is designed for a maximum current of 100ma to actually run the amp, the driver and the output tubes. The 6AS7's want 80ma each, or 160ma for two. This excessive current may well damage the amp.
