I really wonder here why are you guys attacking OP?
is Foobar is the ultimate absolute (nothing can be better)?
what about professional recording player then?
lets put it this way, why is foobar sounds better than other(winamp, etc)?
isn't it just ASIO (said by you guys), well just put the same ASIO to the other and they will all sound same right? even foobar writer said foobar is not an improvement in soundwise
I'm not familiar with multimedia player, but isn't decoding job is done by the codec? so the decoding result quality will depend solely on the codec, isnt it?
And then it is the player job to manage the decoded file to be send to DAC, and I think this step is what makes difference, it can something like bit-perfect stuff or memory management to ensure the data will be sent on time, something like those
Unless you guys really understand how the program works and gives results, I don't think you can make such a claim like "this is the best program, nothing surpass it", so the only way is to try the program itself, if you feel it is the same then so be it.....
and for the Lilith, hmmmm, sounds a bit different than foobar, but just not enough to drag me off from the convenience of foobar
