- Jan 1, 2014
Could a cable issue. Is it a balanced cable? Just wanted to make sure. Cheers
So it turns out I got a V2+ and they did upgrade the opamps inside, so I flashed the firmware provided to me and it is now a V2+ Infinity.
Sounds a little bit better than my 1 year old one too. Great piece of gear.
Ok. I'm going to bring this up again because I am SO damn pissed and other people can potentially get hurt. The f'ing gov2+ ONCE AGAIN loaded up on 100% and blew my ears and my headphones. I've NEVER been exposed to that kind of volume and I'm a freaking DJ. Now my ears actually hurt. This is irresponsibly dangerous.
Be careful out there.
What device is this with? It maybe due to your device since the GOV2 volume is controlled by the host (for instance Windows always remembers the volume I leave it at).
GOV2+ w/ Windows. no enhancements. It USUALLY remembers the volume. But this last time (and a few others), it started up at 100%. I'm surprised my ears aren't actually bleeding right no
GOV2+ w/ Windows. no enhancements. It USUALLY remembers the volume. But this last time (and a few others), it started up at 100%. I'm surprised my ears aren't actually bleeding right now...
SE sounds crystal clear but balanced even though with a wider soundstage, sounds muffled. using manufacturer cables from sennheiser for hd800.
Most likely yes. I have a surface pro 4 and I needed to have access to more than one port so I used a hub. I OFTEN use a hub with the gov2+. Same hub as always.
the thing is ... when in doubt ... do NOT put the thing up at 100%!!!! That seems like a negligence lawsuit waiting to happen.
edit: I just plugged in again. Different port, same hub. This time it remembered the previous volume.
So what differentiates the V2+ from the V2+ signature edition, apart from color? Are there any noticeable SQ differences between the two?
