willowbrook
- Oct 25, 2012
Can anyone of the go2a owners please tell if it has hiss / noise with highly sensitive c(iem)?
I don't know where you get that from but it's pretty hissy from balanced output...like enough that i don't want to listen with ifi iematch with andromedas.
I mainly use my GOV2+ with my iPhone.
I just got the Belkin Lightning Audio + Charge RockStar so I can charge and listen to music at the same time.
Despite it saying on the Belkin website that it would only support Lightning audio at 48KHz it works fine playing DSD128 through my GOV2+ while charging.
I thought you can't charge and play at once.
Can, but the charging doesn't keep up with the battery drain is all, according to others at least (I haven't ran it like this long enough to find out). Actually this might be relevant to the problem with the power light you mentioned- this is the only time the blue power light come on for my unit at least, when it has usb power and is on at the same time (without the usb power connection I just get a quick purple flash from this light when turning it on, when only charging, the green light).
