KOJO KM01-BRASS : With a (32Ω) 20mW +20 mW impression and appreciation thread
Feb 16, 2014 at 6:04 PM Post #181 of 281
Thanks Rudi,I left it unpolished just for the photograph to show the slightly "aged" effect. :) Each time after wiping it off with a microfiber cloth, the pristine shiny look is restored.
Feb 25, 2014 at 8:32 PM Post #183 of 281
Just got the Kojo today. I did listen to it with dx50 and like its SQ but it is harsh in high notes of treble. Is that normal for the almost new one? Would the harshness be less?
Congrats for your new Ko Jo brass edition
I heard many Ko Jo in brass edition ,all sounded not harsh in the high
Very smooth silky clear and clean sound with strong in midrange
This is the first time I heard that Ko Jo high so harsh
Normally for all other amps the first sound out the box are brighter , after burn in will be less bright
What kind of cable do you use ?
What kind of iem / hp do you use ?
IMO
Feb 25, 2014 at 8:41 PM Post #184 of 281
IMO
IC is dyi and litz pure copper silver platted (this cable normally sounds sweet and not bright).
IEM is Shure SE535 clear.
Feb 26, 2014 at 11:43 AM Post #187 of 281
Well I don't encounter such high issue if the similar set up. I believe u should check your file.
Rgds,
Could it be the music I downloaded (128 bps) and they are not WAW or FLAC.
That is not true since I have switched to ipod 5.5 as a source using ALO imod IC cable (copper) I do not hear any harshness. The music was downloaded from itune copied from CDs (253 bps)
Mar 14, 2014 at 6:02 PM Post #188 of 281
My nite time Simple rigs
Source : ak 100 Final Audio Design Edition
Amp : Ko Jo KM 01 Brass Limited Edition 300 pcs
Headphone : LCD XC
Cable : mini to mini Crystal Cable Dream line series
SAA Endorphin balance 3 pin use Abyss adapter to balance 4 pin and use 4 pin to mini plug
High : very smooth and clear
Mid : very sweet tube like midrange , very clear and clean
Bass : very good impact and bass speed
Separation : very good music separation
Soundstage : like in small jazz room
Overall : with this set up , LCD XC sound so sweet and never get boring , I can listen for hours before sleep
This sound quality is like tube sound quality
For nite time mostly I use close headphone , that not disturb :Dmy wife
IMO
Mar 16, 2014 at 10:42 AM Post #189 of 281
Headphone : LCD XC
IMO
Rudi,
Congrats for your Crystal Cable Dream line series!!
I hope it sounds like a sweet dream!
Mar 17, 2014 at 4:34 AM Post #191 of 281
OMG, Dream Line is like 8,000 RMB for 2-wire version and 14,800 RMB for 4-wire version respectively (DIY ones made from interconnects)
http://item.taobao.com/item.htm?id=19604569207
Did anyone find a place that's selling the official Crystal Cable flavor?
My mini to mini is 3 wire cost about 900 USD , SQ is excellent
Mar 17, 2014 at 6:54 AM Post #193 of 281
That's cool, thanks a lot.
Another flagship from Wireworld is roughly 50% of Dreamline at US$450.
3.5-mm to 3.5-mm (AK100 to KM01-BRASS)
http://item.taobao.com/item.htm?id=36127718121
3.5-mm to RCA (Hugo to KM01-BRASS)
http://item.taobao.com/item.htm?id=37797373634
I have similar. From Wireworld mini to mini
Crystal cable Dreamline is the best
