anindyameister
- Feb 15, 2017
The CSR8645 chip which is pretty common among the neckbands, including the EP52 does support AAC decoding, but doesn't seem to be enabled for most cases. I suspect it has something to do with Apple certification/licensing. My Fiio BTR1 is a v1 piece, which lacks AAC streaming with iPhone/Mac even though the chip has support for it, only recently a v2 of the BTR1 came out that works with AAC.Doh!
I made the same mistake, ordered the cheaper one without realising that it didn’t have Apt-x
Interesting if you look at the apt-x version listings the chip the mention using is exactly the same as the Meizu EP52 you mentioned above!
Although no mention of AAC on that!
Does anyone know of a similar form factor that does have AAC? (Either naively for KZ or that can be spliced?)
Thanks
One interesting piece of news is that Xiaomi has just launched a bluetooth neckband earphone in China, priced at 299 Yuan, which prominently mentions AAC support, could be legit.
http://item.mi.com/product/7840.html
