Major congratulations, Huxley.
Are the music ends of the both Yamaha and FX80's the same diameter? I ask because I had returned Yamaha's solely on fitment issues; rediscovering it, I suspect, by way of the FX80. Currently working it out with the FX80 with Monster gels and eventually trying the Auvio.
Also, interested in your assessment among the two IEM's.
The jvc's are a fraction bit smaller than the yamahas, but the tips they use are thicker so it works out about the same.
But the jvc's don't require a deep insertion unlike the yamahas, so you'll probably be fine with the fit there.
Also the yamaha tips will fit the FX80's, a bit loose but it works well, not much difference the yamaha side might be a bit more spatial.
As for sound differences, the yamaha's seem to be a bit veiled after listening to the jvc's, but are more spatial whilst being more intimate and forward both with vocals and instrumentation.
The jvc's are very airy, so vocals sit a bit further back, but everything has a natural timbre, treble is also sparkly but never in your face, piano keys come across exactly as you would expect.
Neither is better than the other tbh, though the more i listen to the FX80's the more i enjoy them.
However for dance/edm the yammies still reign supreme, they have much more energy and are such fun to listen to.
As for which one i would choose, i would say the jvc's but if im honest they're both great iem's.
One thing i noticed with the jvc's, upon first listening they had what seemed to my ears a midbass hump. A bit off putting but with burn in it's backed right off, treble has smoothed out and the details are more present than ever.
