Mackem
- Sep 6, 2011
So it's probably been mentioned a ton of times before, but where's the best place to get the 750/850 shipped to the UK in terms of price and stuff?
Just got my woodies recently. Any suggestions for aftermarket cables which goes well with the fx850? Also noticed the noise isolation is not that good. The person beside me can hear clearly to what I am listening.
OK. What about after market cableThen you are listening to your music pretty loud. I assume you are listening at around 75% volume? Or the room is completely silent.
If you want better isolation, get FXZ200, but it has a smaller soundstage and slightly less treble. FX850 is vented, impossible to get a good isolation.
I have no idea about that. I never felt aftermarket cables make much difference. But that's just me.
Search up FX700 with aftermarket cables on head fi. Not recalling anyone has done it with FX850, but I believe some members have done it with FX700
Does anyone know if the SXC 24 from Alo works well with FX850?
I just received my FX850 this morning....out of the box wow
same here. Isolation wise not that good. Hopefully I will be able to compare with IE800 soon.Yes they are very good. but the isolation...
Need to use IEMs on the go
