slick530
- Jul 26, 2014
I'm looking at getting the universal Roxanne'a as there is no place to get impressions made and I'm concerned about later changes in fit as I get older. Does anyone have experience with the universals? Thanks. I'm ready to pull the trigger but want to hear thoughts on the universals first.
As I said earlier, at this current stage with JHA, getting the uniRox is the wisest thing if the sound is what you're looking for. But you really have to demo it to see if your ears can fit them properly. It would help if you can bring along several kinds of tips (foam, silicon) to get a better seal. I believe the majority of people should be able to adjust according. Do expect the uniRox will protrude a little but that does not affect the sound quality whatsoever. Hope that helps!
