goodvibes
- Dec 28, 2009
but i think it is important to note the difference to people using what ever they can get their hands on for mastering versus a claim that a system is built for mastering. when thinking about the latter , to say a system is built for mastering is to benchmark with the best audiophile speakers and amps throughout history some well into hundreds of thousands of dollars for a installation into a room treated with many thousands of dollars of materials . if the layla and angie support their claim that their accurate enough to hold up to the mastering benchmark of those many tens of thousands of dollars and more systems $2,500 or more will be very little.
Rooms are not the same as speakers used and an IEM isn't dealing with rooms. The sort of sound treatments you're referring to is more about recording bleed than pure mastering where you would simple have to tweak the space a bit anyway. near fielding in space is a way around that as well. This is way off topic. I'm done. Believe what you like but I strongly disagree and have some 1st hand knowledge of it along with owning the sort of home kit that you think all good studios use.
