- May 9, 2011
Impressive. That must be the better part of ten grand sitting there.
The best part of ten grand...
Full Carbon Fiber Roxanne with black AK380 together with the accompanying amp.
Thanks.. I've tried every single type of tip you can have and nothing sounds better to my ears than these old school triple flanges.
Congratulations on your new Mojo again!
I understand you, having to do a lot of work to find the best combo myself, but I have to imagine that those triple-flange tips will make the Angies stick out a bit more than say, the supplied silicons. Is this the case, or are you able to insert them that deep into your canals that it makes little difference? What brand are they, btw?
I'm auditioning my Angie+Mojo using the SpinFits I pictured - so far, so good
I own the Angie II and also owned and returned the Rosie. Of the 2, the Angie's are the better because of its forward vocal tuning and presentation.
The Rosie did have some sibilance, but the Angie's do not suffer from any and I've owned them long enough to not have heard it even once.
The Angie's have plenty of bass that can be tuned by the pod obviously, it's not lite on bass either I have settled on 1: o'clock As a preference.
I mostly listen to progressive rock. But I do listen to other genre causally. The Angie's are excellent for vocals and are tuned a little to the north of neutral.
...The Angie's are excellent for vocals and are tuned a little to the north of neutral.
woah angie2 and mojojojo everywhere
I think the problem was Mojo with your situation. It has a excessive mid-bass and aggressive mid-highs. I found it very musical but it was incompatible with Rosie...
I've never had the pleasure of auditioning the Rosies but I agree with you that the Mojo won't make every IEM sound their best. I wouldn't, however go as far as saying the Mojo has "excessive" LF or "aggressive" mids. I do feel that the Mojo is on the warm side* and thus if you have warm IEMs the combo may turn out to be overly-warm / forward for some.
*Alas, not warm enough for the Etymotics ER-4S...
