cdsa35000
- Oct 14, 2014
Yeah, I just ordered this pure Silver cable instead of the stock silverplated copper, you can choose the plugs.What's very interesting, is that you had/have lots oh high end headphones ( expensive ) yet you rate these earbuds very high.
One of the few best headphones for me is the Pioneer SE Master 1, i really like it and if the earbuds sound even 10% like it, I will be very happy.
Also I would like to try the new IE900, so you have experience with any?Reply
Also is it worth upgrading the cable to a better one and maybe a 4.4 balanced termination?
The earbuds are very cheap, lots of people should buy one at least to try them out.
I remember and still use Blon BL-03, and the Monk, the 5 USD earbud.
LN006247 8 cores 99.99% Pure Silver Earphone Cable For Shure se535 se846 MMCX AKG N5005 N40 N30 Custom armature in ear custom
[Transaction Screenshot]
$52.82 X1
Product properties: 3.5mm 3 pole 1.25m https://www.aliexpress.com/item/329....store_pc_allProduct.8148356.2.41e27af83YNMox
I wont bother the exorbitant ie900, for fuller bass/wide imaging sounds still needs bigger diaphragm to move bigger amount of soundwave in thev air around. Too tiny diag. wont make it and you cant drive it louder either it distord heavily or popped it.
EP05 have found the golden ratio here. enjoy.
