For those interested and if not mentioned before you can add KaiserTone and Capriccio to the list of respectable music player apps...
iPhone 6 & 6 Plus Audio Quality
- Thread starter Baroninkjet
- Tags
- apple
moedawg140
Grand Master Moe "G"….Don't crossface me, bro!
Ping Pong Champ: SF Meet (2016,2017), CanJams (London 2016, RMAF 2016, NYC 2017, SoCal 2017, RMAF 2017)
Looks like I'll try those out as well! Thanks for the recommendations.
Edit: Just saw KaiserTone is $9.99 USD. I will let others try it out first, hopefully comparing the SQ to Neutron and/or Onkyo before I purchase that one. Trying out the free version of Capriccio now...fast forward to later this evening...Now that I was able to compare Capriccio with Neutron, I will give the edge to Neutron as have a slightly more coherent and resolving sound. The navigation is unique with regards to Capriccio, and I like the "Fire" song that accompanies the application, but Neutron and Onkyo are still my recommendations as having exemplary sound signature capabilities.
Baroninkjet
- Nov 18, 2012
Anyone run across any premium apps that will play Spotify files? In Android it is not hard to access and play downloaded files, but have not tried Neutron or any others on iOS.
The only app that I have found for Spotify is SpotEQ. Very useful that it has a decent EQ and allows you to organise your playlists alphabetically.
Baroninkjet
- Nov 18, 2012
Yes, I have it but never use it. It's annoying that it saves its own files in addition to Spotify files. And it is not sufficiently developed to use on its own.
I don't keep Spotify files offline. Keep them offline in SpotEQ.
I would have thought that it cannot operate on its own as Spotify is a subscription service.
SparkOnShore
- Oct 26, 2014
There is Audyssey which can now stream Spotify files and offers really good SQ.
Baroninkjet
- Nov 18, 2012
Thanks! I downloaded Audyssey, but it does not have Westone yet.
SparkOnShore
- Oct 26, 2014
You are welcome...As far as i saw over some months, they renew their eq-dsp collection process quite often. I presume there will be Westone inclusion soon enough. In any case you can also customize settings to your preference...
elfary
- Sep 29, 2005
Put head to head my iPhone 6 against a Fiio X5 using Westone W50 and Westone UM3x...the iPhone 6 held superbly. Id say X5 did the soundstaging a pinch better. But overall feel was so close that i'd never bother with the X5 unless i had volume problems.
Fear the man wearing velcro strapped sandals, for he has nothing left to lose.
Thanks for that. I'll check it out when I get home from holiday. Do you know if you can listen to offline files or does it have to be streaming?
moedawg140
What music playback application did you utilize with your iPhone 6?
SparkOnShore
- Oct 26, 2014
When in airplane mode audyssey cannot synchronize at all with spotify...
Accudio Pro has many more EQ tuning profiles but doesn't have spotify...
Sent from my iPhone using Tapatalk
SparkOnShore
- Oct 26, 2014
Also Accudio has a rather inferior interface comparing to Audyssey. It shows you all your library and does not separate which albums are in iTunes cloud and which ones are stored locally thus able to be played. Audyssey immediately takes you to your iTunes albums which are stored in the device without mixing with the cloud ones, since it cannot stream the cloud albums. Audyssey can only stream spotify but not iTunes cloud. Also the SQ of Audyssey is superior from the one of Accudio which just applies a flattening eq to everything giving lifeless results to all headphones / IEMS...
