New to kickstarter. How do I choose multiple reward tiers? :O
Introducing Trinity Audio Engineering
- Jan 18, 2013
I don't think you can
I'm disappointed that there isn't a "terrific trio" tier. I stuck with the dynamic duo, in the end.
- Jan 30, 2011
Once you've created a login you should be able to select the next after completing the first one. Just add to it.
- Jan 30, 2011
I'll ask Bob about the trio - mention that there would be some interest.
- Jan 18, 2013
That doesn't work for me. I can change my pledge to another tier, but not add to it. Am I doing something wrong?
- Oct 31, 2008
hello boys and girls, thats my Hyperion review now up too.
http://www.head-fi.org/t/761350/trinity-hyperion-review-by-mark2410
http://www.head-fi.org/products/trinity-hyperion-dynamic-iem/reviews/12839
- Jan 30, 2011
I see what you mean. Bob will be monitoring this page. Likely to be a small glitch - I'll find out what's happened and report back later.
Yeah
Getting the same problem. They dont want our money. They want to give us free samples.
- Jan 18, 2013
I don't think Kickstarter allows it.
Definitely need that Terrific Trio tier
- Jan 30, 2011
Working on it lads - patience is a virtue
It is only the first day ......
- Jan 30, 2011
OK - at the moment you can only select one reward - I'll try to find a work around for that one.
The Trio is also up at 110 quid.
To change your selection - look at the top of the page where it says "you're a backer", and click "manage" - you can then make changes by following the logical progression.
Assuming there can only be one choice for each backer - what other combos are required?
BTW - another way of doing this is getting a friend to also register, or using a second email and login .......
- Jan 18, 2013
Cool - upgraded my pledge. I got the first Trinity tier.
Thanks for not only this, but all the other effort you've put in (not just for Trinity, but all your reviews, too!).
- Jan 30, 2011
Another update - from Bob
So solutions:
Sadly its a KS rule.
Can I pledge to a single project more than once?
On Kickstarter, it is only possible to pledge to each project once from a single account. Accordingly, backers can only choose one reward tier per pledge. However, you can change your pledge amount and reward selection for as long as a project is live.
So solutions:
- Choose carefully
- Have another member of household or friend create login and order the extra for you
- If there is enough interest in a particular combo - I'll let Bob know and see if it is worthwhile pursuing. You can see how low he's priced these to get the project off the ground, so we need to be realistic about making it worthwhile for Trinity.
I'm interested, I think like someone else on the forum stated before, on getting the Hyperion + Friend combo together with a Delta. But it would be a clusterduck if all combo options are gonna be available ain't it.
- Jan 30, 2011
Yep - that's why I'm suggesting putting only one or two of the most popular options in front of Bob and seeing if he's keen. At the end of the day it's going to be up to Trinity.
