hongky
- Mar 13, 2013
On my unit I can't select dual DAC even when 3.5mm headphone connectedTesting it right now:
- Single/Dual switch works fine if you have headphones connected for single-ended output. In balanced it works in Dual DAC by default.
- Can confirm the default volume switch doesn't work, reported to software team.
I see no problems with the Shanling Music pausing when headphones disconnected. Please make sure the switch is in the On position.
Music keep playing when headphone disconnected (setting already on "ON" positions)
This is much to high if you use iem on turbo gainUpdate on the default volume:
The Default volume setting works only for Pre-out output. For headphone output, it's locked at the 20 level, to prevent any accidental high volume to headphones. This is decision by head engineer.
