hongky
- Mar 13, 2013
Apart for those issues, everything greatsSorry to hear that you have issues with the new player module. How do you like it otherwise?
Will get to you back on this around February 27th.Thanks for trying
Then I'll wait for @Shanling
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Sorry to hear about that. Yeah.. sounds like one of the Korg tubes have gone. I guess the authorized dealer would be able to help.Was going to listen to my M30 tonight but only one of the two Korg tube lighted up on the right channel. The sound is less loud on the right channel. Running in transistor mode, the sound is even both channels and okay. Who can supply the replacement tube module? Is this user serviceable? Please help.
Time to nudge the engineers?I asked Engineers for this specification, so far haven't received it.
I would recommend 2V
Save that everyone is on the Chinese New Year holidays right now. Til Feb 27th. See note above from @ShanlingTime to nudge the engineers?
Hmm... I usually switch mine off when I am not using it... So, I might not be the best person to help with this question. Insofar as switching off and on again, nothing notable in respect of battery drainage.@Kiats did you observe huge battery drains with your unit ?
I let it idle overnight without playing music, and battery drop around 25%
Yeah ... it's normal if I turn it off, but it shouldn't drain this muchHmm... I usually switch mine off when I am not using it... So, I might not be the best person to help with this question. Insofar as switching off and on again, nothing notable in respect of battery drainage.
@Shanling please check if this is normal behavior for this unit
Thanks
How much is it and from which retailer? I am good at DIY and should be able to do this myself. Can you provide me with a service manual and a part number? Can I just buy one module instead of two? I have less than 500 hours on this unit so I am somewhat disappointed by the lifespan of this tube module.This is most likely dead tube.
Replacement tube modules can be ordered through our official distributors, they come in matching pairs.
Tube module replacement requires a bit deeper access to the main chassis and disconnecting a few cables there. We recommend to either have it done by repair team of distributor or some local Hi-fi shop.
Tried it, never received any info on this.
Will check on it.
@Shanling what about this problems ?@Shanling there are some issues with this new player module
# Can't select Dual DAC, always back to single
# Setting volume at boot not working. Whatever number I set, it always boot at volume 20
# Setting "Pause when headphone disconnect" also not working
No2 I think firmware issue because Kiats also experience it.
