Introducing Lotoo PAW Gold
- Thread starter audionewbi
- Tags
- lotoo-paw-gold lotoo
xnuthecaveman
- Mar 28, 2012
new firmware:
http://download.lotoo.cn/download/PAWGold_Firmware_5.0.X.25_Multi_Language.zip
1、optimize M3u、flac file parser.
2、system stability optimized and improved.
for english, I was advised to useWE CH
EDIT: Lotoo sent me a FW which works: https://mega.nz/file/H8og1KxT#c6CqDRort7hYj4WvFc46oCyn5jlj88FqKWgRDhQrdyY
- Mar 20, 2012
Thanks! Amazing that they’re still updating the fw for this lovely machine.new firmware:
for english, I was advised to use WE
The Lotoo Gold remains that rare thing - a DAP that actually looks good.
Tawek
- Nov 18, 2015
for me it is the most beautiful dap ever created , the size is perfect
- Jan 12, 2014
I still listen to it from time to time. Still sounds great.
- Mar 20, 2012
anyone installed this yet? I get a 'Regional Version error!' after I copied the WE PAWGAPP.COE file to the SD card and hit update Firmware....new firmware:
xnuthecaveman
- Mar 28, 2012
I have not tried yet. let me check with Lotoo
MH01
- Oct 2, 2013
Is there a special way to update the firmware?
I copied it onto the root of the SD card and tried to update it , and for the following error "invalid PAWGAPP.COE .
xnuthecaveman
- Mar 28, 2012
Lotoo sent me this: https://mega.nz/file/H8og1KxT#c6CqDRort7hYj4WvFc46oCyn5jlj88FqKWgRDhQrdyYanyone installed this yet? I get a 'Regional Version error!' after I copied the WE PAWGAPP.COE file to the SD card and hit update Firmware....
xnuthecaveman
- Mar 28, 2012
it should be correct. file saved on the root of the SD. what I use though is an empty SD FAT32 formatted 8GB.Is there a special way to update the firmware?
maybe try this for English https://mega.nz/file/H8og1KxT#c6CqDRort7hYj4WvFc46oCyn5jlj88FqKWgRDhQrdyY
MH01
- Oct 2, 2013
Thank you sir. That worked perfectly.it should be correct. file saved on the root of the SD. what I use though is an empty SD FAT32 formatted 8GB.
- Mar 20, 2012
Worked perfectly, thank you.
Does anyone has LR unbalance issue when switch from low gain to high gain on your Paw Gold?
Dobrescu George
Reviewer: AudiophileHeaven
Does it go away? Some sources can have an intermittent L/R balance issue for a brief moment when switching between gain modes, did not notice it with any Lotoo products, but I've seen this before, but if it goes away, it is not a cause for Worry I would say.
