waveriderhawaii
- Feb 14, 2014
Will the FiiO X3 drive the Fostex T50RP or will it need to be amped? Would like to use the Fostex's portably if possible.
I use a Sansa Clip+ with FiiO E06 and Koss KSC75 or Senn HD 239.
Listen to various genres - jazz, prog, metal, etc. in FLAC.
Will there be a significant improvement replacing my player & amp with a FiiO X3 and stay with the same headphones?
Thanks
You will gain a lot more by upgrading the headphones first
Coming back to this.
I now have the Somic MH463. Will it be a big improvement replacing the Sansa & E06 with the FiiO X3, now? Will I get a comparable sound as on PC?
When i use the Somics with my PC (ordinary on-board sound), the sound is much fuller and dynamic than with my mobile setup.
Thanks
The X3 will probably be better than your computer's sound card. If you say your PC sounds better than your clip with the E6 then I would have thought that you would notice quite a big difference with the X3 over the Sansa clip.
Why not to wait the X3 II now ?
