[Impression] FiiO X3 – High Fi, Low Price.
- Thread starter ClieOS
- Feb 23, 2011
I'm subscribed too. I've been looking for an alternative to the Clip Zip but I might not like the house FiiO warm sound.
BigDave
- Jan 20, 2004
Damn, and I just forked out for a cowon d20.
Seems like a fairly large battery. Surprised that it only lasts for approx. 10 hours or so.
ninewalker
- Apr 14, 2013
Thanks for the review ClieOS. So I guess album art isn't supported on flac even if it is embedded. A very minor quibble I guess but would like to see it in a future firmware update.
Yes, each new feature may adds some bugs and spend time to test, so we now try to fix all the bugs and make the current firmware more stable,
some new features will be added in the future.
1, AIFF support.
2, Album cover of FLAC, WAV, APE, ALAC and other format.
1, AIFF support.
stain3000
- Apr 1, 2013
How about comparisson with ihifi 960?
ninewalker
- Apr 14, 2013
1, AIFF support.
Perfectly understandable. Thanks James!
goodvibes
- Dec 28, 2009
Likely needs an additional or larger buffer implemented. I guess it depends on how one feels about buffers that 'should' be inaudible.
Why would anyone turn gapless playback off? Is there any downside with its implementation?
I can compare it to any DAP if you are willing to send one my way
thegunner100
- Jul 30, 2012
Clieos, do you have a headstage arrow or a pico slim? If so, could you put it under the x3 so that we could see how thick they would be together?
Edit: an E17 instead of the x3 would work too, since they're about the same thickness.
fearwhat
- Jan 4, 2013
Subscribed! Really great review! Guessing I'm gonna make choice between the X3 & DX50
Hope the wait won't be long
Nice review, might consider this to replace my U5
Afterparty
- May 2, 2013
hey man, a bit offtopic but any chance for a review on the d20?
- May 5, 2010
That's because of the high output power. Your D20 puts out 29mW per channel @16ohms, whereas the X3 is pushing out 300mW @16ohms. 500mW @16ohms. (as noted by JamesFiiO below)
X3 is pushing out 500mW @16 ohms,
