iHiFi 990
- Thread starter walfredo
I can also unscramble/scramble the system binary file so it's now 'about device' is back to ATC as opposed to Xuelin (it will work on either).
ATC say a new firmware is now in testing for release (no idea on changes but it's a step forward over Xuelin)
My new firmware is up jump to this thread:
https://www.head-fi.org/threads/atc...-high-res-players-akm4490-dual-wm8740.853830/
theMUKe
Is this 0.11 beta? Or is it a different .bin file with ATC?
Hi theMUKe,
The stock ATC firmware is 0.12beta but it's identical to Xuelin's 0.11beta apart from the ATC startup/shutdown screen. It even has to be called hf990.fw to flash. The good news is ATC have finished a new firmware which is in testing. It will work on xuelin also (plus i'll be modding it)
I'm also working on a few updates to my current mod.
Let me know if you want a Xuelin branded firmware mod and if you want the tape deck back in it or not (or even back in as an option in themes)
padre1984
- Dec 13, 2016
Hi,Let me know if you want a Xuelin branded firmware mod and if you want the tape deck back in it or not (or even back in as an option in themes)
I think that the xuelin branded firmware for xuelin branded players will be better. And if you can please do it.
theMUKe
Not sure if I like the tape deck so much... Think the other UI is nicer.
New Nayparm Theme v1.1 Fw here: https://www.head-fi.org/threads/atc...ers-akm4490-dual-wm8740.853830/#post-13923789
Next will be Xuelin branded version
Xuelin branded version going well
Xuelin Version up
Xuelin IHIFI990 - Nayparm Theme V1.0 - FW 0.11beta.zip
https://1drv.ms/u/s!AjIqgYlV9XYygznbfYXTfkuAtmwa
To flash you must be using a fat32 formatted microsd card.
Copy the hf990.fw to the root of the card and:
Either using Settings, Firmware Update option.
Or with the power off hold back (bottom button on the front) while pressing power.
walfredo
- Aug 7, 2010
Thanks, Nayparm!!
Do you folks feel any sound difference with the new firmware?
soundblast75
- Nov 30, 2012
guys, can anyone tell me what coaxial cable works to hugo/mojo, i got one from Penon 3 pole, but no luck
ganjor86
Do you solve this problem ? I hawe that same problem with atc hda-dp20 ;(bzfrank
I have some issues with the device. After charging it shows full, but then I turn it on the battery indicator shows not full. Total charging time is one and a half hour, it's a little bit strange for 3000mah battery? I use regular 1000mah phone charger. Total run time around 6 hours, playing only hi-res flacs.
Xuelin Version up
Very interesting, thanks!
Question, does this firmware "override" official ones? I mean, does this brings all original firmware changes plus your improved UI/functions?
Or, in case, I have to update first with the original firmware and then use your?
Cheers!
Cheers!
Yes the latest xuelin firmware plus my changes so just flash this. Please note, only english has been modified. All other languages will be as was (apart from the graphics)
