curentatu
- Nov 19, 2016
is it possible to use both the headphone out and rca out at the same time on the Micro IDSD ?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
thank you.
I have ordered the iDSD signature, but... seems it's the wait time is longer than expected, it was told on the french site where I ordered 7-15 days, but in fact, nothing will come before mid january. nothing serioux that I can't whistand though![]()
I have an OG silver micro iDSD, how do you disassemble it? Does anyone have a video or set of pictures to help? I see that there were metal spikes (or rails IDK) that would hit the side switches if I tries to remove the board by sliding the outer shell off.
Yes. It is a simple DIY project. Just upgraded mine today to a larger external battery.Battery Replacement is not an end user DIY project... You need to send it to iFi Audio... This has been discussed already by iFi Audio...
http://www.head-fi.org/t/711217/ids...the-meaty-monster-page-124/1365#post_10713255
Post in thread 'iDSD micro Black Label. Tour details (page 147). Release info (page 153).' https://www.head-fi.org/threads/ids...47-release-info-page-153.711217/post-16736714
Same issue with me since day one... really bad quality control...i used contract cleaner and it works for a while, but after a few days it does the same again. Love its sound, hate its construction quality. Volume knob also works after 10' (otherwise it has serious imbalance). How did you manage to open yours ifi? Is it easy if i remove the four screws at the front of the unit? Should i be carefull and be aware of anything else?Hi everyone!
My Micro IDSD Black Label is causing me some troble because of the IEMatch switch. It's causing distortion to the music and channel imbalance, because it's not a good switch and maybe there's something loosen inside it. I'll try to change it, but I can't find any replacement switch like those to change.
Does anyone knows how can I get a new switch over the internet?
Thanks!!!
Overall this switch seems to lack quality, like all other BL switches, They don't change positions firmly, and everytime I have to adjust them to the righ position.
I had the same issue with the first version of iDSD Micro (silver one). Both the Black and "Silver" ones use the same low-quality switch for IEMatch. I am pretty sure iFi was made aware of that issue and resolved it with a different switch in their Signature version later on. Ah, well..... $$$$ happens.Same issue with me since day one... really bad quality control...i used contract cleaner and it works for a while, but after a few days it does the same again. Love its sound, hate its construction quality. Volume knob also works after 10' (otherwise it has serious imbalance). How did you manage to open yours ifi? Is it easy if i remove the four screws at the front of the unit? Should i be carefull and be aware of anything else?
Is it true that if I want to use it plugged in all the time, I can’t use the dac function? I basically have to use RCA inputs right?
