guido
- Jul 3, 2003
Econ or normal with iem match set back one click. Be sure to flip the switch for xbass.
I cannot get enough volume with it set on IEM set back one click..
I have the x5 and it makes a very impressive match for the micro for a transportable.
On a nice note I am sitting with a bottle of Connoisseurs Choice Aberfeldy limited edition distilled 1990 and bottled 2011.Listening to a little Nick Cave,Very special indeed.
I got the apple Lightning to USB adapter. I plugged it direct from the iPad to if I idsd. Got the message drawing too much power. Any help.
i would much appreciate any headphones pairing suggestion with
ifi IDSD.
Unfortunately i have no chance for a listening session so i can not trust my ears.
The sound like i expect is clarity,definition,stage instruments separation,
tight (not necessarily very low) bass .
I admit am not an expert but i have three different choices.
1) Senn hd 600.
2 ) Hi Fiman 400i
3) Beyerdynamic T90.
A more experienced friend advised Beyerdynamic T90 as closer to my listening preferences.
Any suggestion would be much appreciated.
Thank you All.
ps'' Im located in Europe"
went to dealer to listen to ifi idsd micro with hifiman he560. i was blown away. smooth analog sound. i came home with both. what cable do i need to connect my ipad air to the ifi idsd.
ifi IDSD.
1) Senn hd 600.
2 ) Hi Fiman 400i
Thank you All.
ifi IDSD.
1) Senn hd 600.
2 ) Hi Fiman 400i
Thank you All.
I suggest Philips Fidelio X1 and the new Audio-Technica R70x.
Or Shure SRH1540, SRH840, ATH-M50 / M50LE for closed headphones.
Brilliant combo and I can imagine it to be perfect for many ears. It was a little too energetic for me and lacking in body (I prefer a warmer neutral sound).
ifi IDSD.
1) Senn hd 600.
2 ) Hi Fiman 400i
Thank you All.
If you're considering the HD600 and the HE-400i, get the Philips Fidelio X2 which a lot consider to be a direct upgrade (to the HD600) in almost every aspect except usability with high output impedance OTL tube amps. If you're considering the T90, maybe HE-560? Do note that I haven't heard the X2 and T90 myself. Personally, if your friend says the T90, and judging from your description, the HE-560 will be a great choice.
